Water spray and soap dispense
My dishwasher is about 8 yrs old. Just recently the top and bottom sprayers are spraying water but not spinning. They have free movement. When I put it in a rinse cycle, close the door, then open the door after it has ran for a minute the spray wands are in the same position but water is coming out of the holes. Any way to run it with door open to see what is going on.
Also the soap dispenser is opening but the soap just runs down the door and doesnt get spread around. The dishes are not getting clean at all.
Any suggestions.
Replacement parts for JENN-AIR JDB3010AWT | AppliancePartsPros.com
Here is a service manual. I could not find a manual for this unit buy the following looks like it uses the same pump so may be useful.
http://www.servicematters.com/maytag_library/docs/16010622.pdf
It sounds like the filter in the pump is clogged up.
Could also be crud/debris in the impeller area.
