I am regularly getting puddles of water under my crisper drawers and don’t know why, where it is coming from or what to do to stop it. Any ideas?
Most likely the problem with your fridge is a clogged and/or frozen drain in the freezer.
Remove the back panel inside the freezer and check the drain under the evaporator coil. Using a hair dryer and a hot water, defrost and clean it.
- Here are the break down diagrams for the Frigidaire refrigerator Model FRT21LRGW2
