Water not getting to icemaker
Brand: Whirlpool
Model Number:WRS315SDHM05
Main Symptom: icemaker not working
What happens & when: no water is going up to icemaker
Error Code (if any): none
Parts or tests already tried: installed new water filter, water inlet valve and icemaker
Check to ensure the fill tube into the ice maker is not frozen up. If so thaw it out…the valve is usually what causes this, so after the valve is replaced you need to clear the ice from the tube and let is start all over.
There is no ice in the tube. It is not frozen up. I removed the water line from valve and move air through line. It is not obstructed. Water valve already replaced. Could it be my wire assembly in the ice maker. I did not replace that and if I understand it has a fuse in it. Will this keep the ice maker and water working???
