I had water that was left in the bottom of the dishwasher after each cycle. it started with about a 1/2 inch in the trap and has gotten worse to where it is about 2" to 3" now in the bottom of the dishwasher.
I have check all the hoses and there was nothing restricting any of them. I have checked the separator and there was nothing that was restricting it. So I order a new pump and motor and have put it in and ran a test run with nothing in the dishwasher and after a quick wash cycle there is still water in the bottom of the dishwasher and it about 2" to 3". Same problem as before the pump replacement.
Thanks for any help.
[quote=lloyd520;324001]I had water that was left in the bottom of the dishwasher after each cycle. it started with about a 1/2 inch in the trap and has gotten worse to where it is about 2" to 3" now in the bottom of the dishwasher.
Thanks for any help.[/quote]
Lloyd,
You most likely needed the separator repair kit,
With all the checks you’ve made, and the proper checks by the way,
You’ll need to order and install this part,
To solve your drain problem.
Good Luck,
