Last Friday and today, I noticed some water in the laundry room. There doesnt seem to be any leaks in any pipes connected to the clothes washer or the sink next to the washer in the laundry room.
Moreover we do NOT see any water during or after we do our weekly round of laundry (usually around 5-6 loads) during the weekends.
What I did notice was that the water softener was also going through its weekly regenerating cycle at the same time. I confirmed this was the case today and am almost certain I had heard the water softener running last Friday as well when we woke up around 6am. At that time when I saw the water pooled by the washing machine in the laundry room, I assumed it might have been from the wet umbrella I had kept for drying on Thursday night and simply wiped off the water with a paper towel and we did our usual 5-6 loads of laundry later on over the weekend without any issues.
This morning I could hear the softener running in the basement as I came downstairs to the first floor and when I went to the laundry room saw the water around the washing machine (no laundry was done between last Sunday and today morning). After wiping up the water, I quickly inspected the various pipes connected to the washing machine and they looked fine, not wet or leaking. So I went to basement and the water softener was going through the (backwash?) phase where it drains all the water from the brine tank and mineral tank and into the drain. Roughly an hour later, the softener was done with the regenarating cycle.
I should also mention that our basement is unfinished and while looking at the softener, I looked up towards the ceiling and did not notice any issues with any of the pipes leading to the laundry room area (or even the pipes leading to the half-bath next to the laundry area).
Would appreciate some input as to what could be causing the water to pool/leak in the laundry room? Could it be somehow related to the softener running?
Thank you for any input and suggestions!
-Topper
P.S.
Some more info… The washer is a Bosch 500 series… While doing the loads this weekend, I noticed water dripping very slowly and only at the end during the spin cycle… And it seems to be from near the front of the washer (at present)…
