water level
the water level does not work properly
set at high level and it shuts off with less then min amount of water
must reset to high every time till right amount of water is in washer.
Hello,
Make sure there is no water in the washer. Open the control panel and disconnect the pressure hose (clear plastic tube) from the water level switch. Blow some air through the hose to make sure it is clear. Reconnect the hose and give it a try.
If it would not help, replace the water level switch.
  • The water level switch [PART]W10339334[/PART]
Here are the breakdown diagrams and Parts for Maytag MVWC300VW1 Washer - AppliancePartsPros.com
