water keeps running (regardless of level setting) while machine runs in either the washing and rinsing mode.
Jim Cobe
Jim Cobe
Problem: Regardless of water level setting, the water continues to run while the machine is in either the washing or rinsing cycle. Can you please let me know what the problem is and how to fix it.
Thank You
Jim Coble
Hi Tim,
Unplug the washer. It water would not stop, replace the water inlet valve.
Open the control panel and check the pressure hose connection to the water level switch. Blow some air through that hose to make sure it’s clean.
If it would not help, replace the water level switch.
Here are the breakdown diagrams and Replacement parts for Crosley CW22B5V WASHER-TOP LOADING | AppliancePartsPros.com
