replaced bearings 2x - last fix was month ago-went fine-and then after 2 washes OL code goes on after it won’t stop filling- replaced main board thinking pressure transducer was bad-replaced hose from tub and cleaned the bottom cavity -no effect- RPS sensor is good- figured out how to access diagnostic mode- and C0 is fine but C1 mode continues to overfill leading to OL code- Did the factory FD reset- no effect- so wondering how to “recalibrate “ the sensors- stuck on this point
I am not aware of any way to recalibrate the sensors. When it continues to fill, it has to be getting voltage from the control board. So, either there is an air leak somewhere in the pressure sensor tube, the air dome at the bottom of the tub, or the control is bad. I know you replaced the board and air tubing; there just isn’t anything else I can think of.
