Water leaking under freezer
Brand: Frigidaire
Model Number: LFFH20F3QWC
Main Symptom: water leak under unit
What happens & when: water is leaking from insulated Freon line that enters unit from bottom
Does the freon line feel like it is cold to the touch or is it warm? Also, does the insulation look like it has an air gap between it and the freon line, and could you provide a picture of the leaking section?
