Unbeknownst to me, found the dishwasher had been leaking for sometime. Looks like water is dripping from around the water intake valve area. Anyone experience this or ever change this part? I am thinking given the age of the unit it is not something major? Thanks!
Here are hour parts
Replacement parts for GU2455XTSS models | AppliancePartsPros.com
Remove the kick plate and determine what exactly is leaking.
Could be the valve itself but could also be one of the water hose connections.
A small mirror and a flashlight can be useful here.
If you click on a parts picture a new page will open often with a Q&A section about that part.
Looks simple enough to replace.
Undo the screw and move the valve assembly to the right to un-clip it.
