I recently replaced our countertops and had to move our dishwasher around. Since then my dishwasher leaks water out the bottom of machine under the door. It only leaks during the rinse cycle. Is it not draining fast enough or what is the problem?
Kreuter,
Check and make sure the drain hose is installed proper and has no bad twists or kinks.
The drain pump should have the water drained out in 20 to 30 seconds or less,
(let unit fill and wash foe 3-5 minutes, then drain unit and check time).
Check and make sure the dishwasher is level in both directions,
All 4 feet are on the floor, solid.
Insure that the door to tub alignment is proper.
Check and adjust door catch if necessary.
Check lower spray arm for proper rotation, and no stalling.
Run the unit through a short cycle (with out detergent) and see if leaks occur.
If it still leaks after that(in the rinse cycle only) suspect the rinse agent is foaming and blowing out the bottom of door.
Make sure you use the proper amount and type of detergent, per the user’s manual.
Good Luck,
