water leak at front tubing coupler
I have a water leak at tubing coupler part number
“Tubing Coupler 218518700”.
How is this part replaced? Is it a simple push on fitting, meaning do I just cut off the old coupler and push this one on?
The part is very expensive for a tiny plastic 90 degree elbow. Would it be possible to just get a .25 inch fitting of some sort at Ace hardware?
The part is listed here as Water tube elbow - part [B]AP2114732
Thanks.
[/B]
Just found the part I needed at Home Depot locally for $3.47 vs $22+ online - it is the same fitting btw. I have issue resolved and mods may delete this thread. Thanks.
