Water inlet valve
My water inlet valve is not sending water to the ice maker. I contacted Samsung and there answer was, the part is no longer available. Part #DA-03150A. I am trying to find out if I can use a substitute part? I see that part #DA81-05997A/A/S-Assy case filter tank was listed somewhere as a replacement but I do not see any pictures to verify that the water inlet valve comes with this . Can some one please shed some light my dilemma, Samsung is no help. Thank You
Hi, Senor Pescador.
You need to use a case filter tank assembly part number AP5807882
The old valve DA62-03150A crosses over to this part number.
Good lock. Please keep us posted with the results.
Thank you,
Simon.
