Water is entering the drum between usage…it spins fine, but 2 days later, there is water sitting in the drum.
More than likely the water valve is leaking?driping. If you have the patience, you can watch for a minute or two to see if the dripping [U]completely[U] stops. It should if it doesn’t over time/nite it will accumulate. Anothr way is to put a cup or a wash cloth under the feed and come back in acouple of hours to check.
The wash machine was installed 4 years ago and this just recently water started showing up in the drum. The machine works perfectly, otherwise.
The hose connections are still secure and dry. The hoses hook up to the machine on the outside. Do I have to take the back off the wash machine?
