I have a dishwasher that works just fine, however with no power on the base fills with water it doesnt do it all the time. I beleive the fill valve is leaking by. your thoughts please. thanks Herman
The fill valve is solenoid-controlled. If the valve gets fouled, it won’t completely close. You may need to replace it if there is no way to clean it. Check your water for hardness.
[QUOTE=magician59;190842]The fill valve is solenoid-controlled. If the valve gets fouled, it won’t completely close. You may need to replace it if there is no way to clean it. Check your water for hardness.[/QUOTE]
Thanks so much I thought this might be the problem.
