The water & ice dispenser isn’t working at all. No water/ice comes out, no lights, the buttons don’t do anything, nothing at all. It started with the line to the water dispenser coming loose from the spout. A friend decided he would fix it, and during the course of this attempt, one of the circuit boards was dropped in a puddle of water. When it was reassembled, it had ceased to function. I’m assuming the board is now dead and needs to be replaced, but it’s been a while since this happened and I can’t remember if it was the power board or the switch board.
Is there a way to test them to see which is bad, or does the fact that it does nothing at all indicate which it would be? Or could it just be a coincidence, and it’s something completely different?
And, on a related note, what’s the proper type of adhesive to use to glue the water line back into the spout?
