Brand: GE
Model Number: GNE25JMKCFES
Main Symptom: Reduce Wtr Flow
What happens & when: No water
Brand: GE
Hello, my GE Refrigerator has severely reduced water flow from the dispenser, and reduced flow to the ice maker (not as bad as water dispenser). As best as I can tell I am dealing with either a Water Isolation Valve and Jumper Kit problem, or a Water Filter Manifold problem.
I would appreciate any professional advice on helping me to decide which part to buy (I have both OEM replacement part #'s). Thank you in advance.
For your GE GNE25JMKCFES, since you’re seeing reduced water flow at the dispenser and also lower flow to the ice maker, I’d start with a few common possibilities:
A partially clogged filter is the most common cause. The dispenser usually shows the problem first because it needs much more water flow than the ice maker.
A quick test:
Remove the filter (or install the bypass plug if you have one) if you do not you can use a spare piece of tubing to bypass the water filter manifold.
Try dispensing water.
If the flow improves noticeably, you’ve found the culprit.
It’s also worth checking:
The shutoff valve behind the refrigerator or under the sink
Any kinks in the water line
Older saddle valves that may be partially clogged with mineral buildup
A restriction here can affect both the dispenser and ice maker.
If the fresh-food section is running a little too cold, the water reservoir or tubing inside the refrigerator can partially freeze.
Signs of this include:
Very slow dispenser flow
Ice maker still working, but not as well
Problem comes and goes
If the filter and supply line check out, the inlet water valve on the back of the refrigerator may be becoming restricted or weak. This can reduce water flow to both systems.
How old is the current water filter?
Did the reduced flow happen suddenly or gradually?
Are the ice cubes smaller than normal?
Is the dispenser giving a weak steady stream, a trickle, or does it pulse/sputter?
Have you tried dispensing water with the filter removed?
Those answers will usually point us pretty quickly toward whether it’s the filter, a supply issue, freezing, or the inlet valve.
