Water filter housing
After replacing water filter with new one have no water to ice maker or door water dispenser. If I remove water filter everything works fine. Tried 2 different water filters, no luck. Suspect maybe the water filter housing, what’s your opinion? If so can you provide me with a video or step by step procedure on how to replace filter housing. Also what model filter housing do I need to purchase from you guys. Thanks Roy.
Are you sure the filter is snapping all the way in?
Here is the parts diagram.
Parts for Whirlpool GC3NHAXVY01: Cabinet Parts - AppliancePartsPros.com
A video.
Refrigerator Water Filter (part #EDR3RXD1) - How To Replace
[B][SIZE=2]Water Filter Housing [/SIZE][SIZE=2] Part #: WPW10121140
Whirlpool WPW10121140 Water Filter Housing - AppliancePartsPros.com
[/SIZE]
[/B]
Filter is in all the way. Can you help me giving step by step procedure on replacing filter housing WPW10121140 or video.
I found this…
https://www.youtube.com/watch?v=JvMsxF20IT4
I watched that video but my filter housing WPW10121140 mounting screws are with filter housing mounted behind steel frig bracket. Looks like you may have to change it from underneath. If so all fox would have to be removed. Is this the way you see it.
I watched that video but my filter housing WPW10121140 mounting screws are with filter housing mounted behind steel frig bracket instead of outside of steel bracket. Looks like you may have to change it from underneath. If so all food would have to be removed. Is this the way you see it.
I am having a water conditioning system installed for the whole house today. Do I need the water filter for my Whirlpool Side by Side Refrigerator ice maker to work. Model# WR3325FDAB01
