I changed water filter about 30 days ago. Now when dispensing water (ice maker/dispenser is having no issues) fridge makes vibrating noise and water flow is s-l-o-w. So being the handy couple we try to be we replaced the dual water valve, 80 bucks later, nope not the right part. Problem remained unchanged. So I did what I should have done in the first place - removed the water filter. I put in the blue bypass cap and water dispensed fine again. I REMOVED BYPASS CAP. When I did I noticed water dripping from water filter head housing. If you’re looking straight on at it, there is a blue circle and on the top and bottom of blue circle what looks like white screws. The water appears to be dripping from the white screw area. It has a pretty steady drip. So I am confused, does this mean housing is bad OR do these things have O rings that go bad and could cause this? Loving your site and hoping for help. Thanks!
Hi.
Based on the info you provided the filter housing should be replaced 67006524
Here are the breakdown diagrams and Replacement parts for Maytag MSD2651KGW REF - SXS/I&W | AppliancePartsPros.com
Thank you. Post the results.
Simon.
[SIZE=4][COLOR=Blue]Thank you for the response. I ordered the part, are there instructions for installation? Is this an easy enough install for homeowner?[/COLOR][/SIZE]
Hi.
Should not be any problems.
Simon.
I ordered the water head filter housing from your website and while attempting the repair the water filter head housing, we broke the plate filter backing hinge and now needs it needs replaced. I see it on your site, it is as follows.
Item Number: AP4013990
Manufacturer’s Number: 12688503
[COLOR=#000000][FONT=times new roman, new york, times, serif]
[/FONT][/COLOR]
[COLOR=#000000][FONT=times new roman, new york, times, serif]We have no idea how the one in our fridge comes off. Before I order the above referenced part from you, I want to make sure we are able to remove existing one. Do you have any instructions on removal of existing plate filter backing? Thank you.[/FONT][/COLOR]
Hi.
This is very uncommon job. There is no instructions i could find. Use your common sense. Should be couple of screws holding it.
Good luck. Post the results.
Simon.
lucky us. there are no screws I used a mirror to look at that. only think i could think is that maybe it slides on a track. would you mind looking at the two pictures of the part on your website and see what you think.
finally, is there anywhere I can find the information on removing these.
Hi.
Not sure, but looks like it just clips in. Get a new part and that should help to figure this out.
Simon.
Am in the process of installing the water filter head shown in this post. The line to the water supply is clear – connects with a compression fitting. The other line enters a plastic fitting that I’m unfamiliar with. Seems to be a plastic collar with, perhaps, a stem that enters a plastic pipe leading to the icemaker and water dispenser. – not sure how to disconnect the current line – pull, push, pry. Have a feeling the wrong choice will not be good for the connection.
Any help appreciated.
The connection of concern is to the dual water inlet valve – AP4080862 – enters a blue plastic collar into the green plastic pipe
