Brand: LG
Model Number: LSXS26396
Main Symptom: Leaks water
What happens & when: Filter replacement
Error Code (if any): NA
Brand: LG
That’s going to be an issue with either the filter AGF80300704 or the filter head ADQ74813401. It may be worth trying a second filter if the first filter is fully seated, but if the issue continues and you are using the correct OEM filter then the filter head will need to be replaced
https://www.appliancepartspros.com/l-g-package-assembly-c-agf80300704-ap6985097.html
https://www.appliancepartspros.com/lg-filter-assembly-water-adq74813401-ap6334956.html
