kitchenaid model ksrs22qfwh01 water drips from cold water dispenser not sure if icemaker works since water was shut off due to leak at water dispenser is problem with micro switch or valve also where do they hide waterfilter on this unit lol tks
Hi.
The reason for water dripping mainly the air in the water line (water tank) or the bypassing water valve. Check if it’s the valve by disconnecting the line from it.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=249807
The water filter is an external part.
Check the attached link.
Thank you.
Water keeps dripping from the dispenser.pdf (56.3 KB)
