water dripping from inside down on top shelf
[SIZE=3]Water keeps dripping on the top shelf.It is coming from the vent holes in the middle of the ref. Any ideas.Thanks .[/SIZE]
Sounds like you have a clogged defrost drain. You will need to remove the back wall of the freezer, and under the evaperator is a drain pan with a hole in it. It is probably frozen up under there, so you will need to get some hot water and a turkey baster to clear the frozen water out of the hole. You will know when it is not clogged anymore when you hear the water go down the drain
