Brand:Kenmore Elite Model Number:795.72053117 Main Symptom:Dripping Water from dispenser What happens & when: After you are done getting a glass of water from the dispenser, water will continue to drip for several seconds. It will drip enough after a few glasses of water that it fills the tray at the bottom so when the door is opened the water will run off into the floor.
Parts or tests already tried: I was told by AppliancePartsPros.com to order the water valve and that would fix my problem. I replaced the valve last night and it still as the same issue. I spoke with Jason Frost on the phone and he asked me to post a question on here to see what else it might be. I have even replaced the filter as well. Could it be a bad micro switch?
The valve in the back of the unit is a primary valve but would not cause this leaking. The most likely cause would be with the secondary water valve located in the left door of the unit. Here is a link to the part number for the valve. LG AJU74532703 Refrigerator Water Valve Assembly | Genuine OEM Part
