Water drain pump always on
My washer’s drain pump is always running. Throws the FH code. I’ve replaced the drain pump and the water flow meter. Checked all hose and inlet valve. Do you think the control panel is bad?I am lost and tired of not finding a solution!
Hello Here is the failure code and test procedure, take a look at these procedures that are suggested they are in order and will help you make the descision on the ccu boardAP6011715 thank you and good luck!
Strange that your pump is always running. Does it run as soon as unit is started? Does water enter machine? If not, check your cold water inlet valve screen for buildup. (well water causes a lot of clogged inlet valve screen issues) Check to see if your drain hose is inserted into drain pipe more than 4.5 inches. If it is, there may be a siphon problem, make sure it is not inserted too far into drain pipe to prevent siphon.
Good luck
