Water doesn’t work at door but ice does
Brand:LG
**Model Number:**LFXC22526S /01
Main Symptom: No water at door
Not sure what part to replace, thanks
When you press the water dispenser, do you hear the valves hum at all?
Yes, I believe there is a slight hum. (I’m doing this for a friend so I’m learning the details as we go lol)
If the left door is opened, there is an access panel on the bottom inside of the door that can be removed. This will expose the dual water valve and water tank. The tubing at the white collar and the orange collar can be removed and the valve mounting screws removed. This will allow a flow test to be done. Place a refrigerator magnet on the door hinge cover close to the inner corner to activate the door switch. Aim the valve into a cup and briefly press the dispenser. Does water go into the cup?
No water comes out. What is next step. Thanks
As no water came through the valve, we can safely say the valve is the cause of failure since it does hum when the dispenser is activated. Here is a link to the valve that would be used with this model. MJX41869202 Refrigerator Water Inlet Valve | Genuine Lg OEM In Stock
Replaced but water won’t flow?
If the valve is disconnected like in the very last test, a magnet placed at the door switch, and the dispenser pressed while the valve is aimed into a cup, does water dispense and does the valve hum?
