The F2E1 error means there’s a stuck button on the user interface, F6E2 indicates a communication issue between the user interface and main control, and F7E5 points to a shifter failure. Usually, whichever code appeared first in diagnostics helps identify the root cause — in this case, it’s most likely a user interface failure. When the washer doesn’t fill, does the lid lock engage, and does the user interface still respond to button presses? W11106748 Console | Genuine Whirlpool OEM In Stock
