Recently the in-door water dispenser has become “sticky” in that it takes a bit of a push on the control arm to start the flow of water.
Today, the whole thing got stuck in the open position and I wasn’t able to get it turn off. I had to pull the fridge out and turn the water off at the back. It was a huge mess.
Not sure what this whole thing is about. Does it need a good cleaning? Does the on/off arm need to be replaced?
I’m about to try to clean the assembly with a steam cleaner to see if I can get it work smoothly, but any help would be greatly appreciated.
Thanks very much.
