The freezer door water dispenser is sticking on intermittently. However the ice dispenser is functioning just fine. A common switch in the door control panel appears to activate both functions depending on which is selected. Can anyone give me a pointer on what may be failing? I’m guessing that either the Solenoid (part # wr62x10055), located in the door, or the Water Valve (wr57x10032), located at the base on the rear of the refrigerator may be the problem. Any help would be appreciated.
What did you do to stop it?
Turned off the water on the main supply
Next time remove the wires from the water dispenser solenoid on the water inlet valve (the blue one).
If water would not stop, replace the water inlet valve. Otherwise post the result and we will proceed with further diagnostics.
- The water inlet valve AP6995571
Here are the breakdown diagrams and Replacement parts for General Electric PSS25NGNAWW Refrigerator | AppliancePartsPros.com
