Water Dispenser not Working
I have a Frigidaire side by side Refrigerator and Freezer with a water and ice dispenser in the freezer side. I’m not sure of the model number because I got it from a scratch and dent place and they tore half the sticker off.
My problem is that the water dispenser no longer works. The ice maker still works fine but I get nothing from the water, although the light turns on and I can hear a slight buzzing.
I’ve gone through a couple of the troubleshooting steps I’ve found on the web like seeing if the tube is frozen on the inside of the freezer door. It’s not, or at least water is not coming out when I disconnect the two tubes underneath the door.
I also just replaced the water valve (240531101). This didn’t do anything for me either. I’m stuck as to what to check next and any help would be greatly appreciated. Thanks,
Ben
EDIT: Also forgot to mention that I tried removing the filter and pressing the dispenser, nothing came out.
EDIT2: Just checked out the reserve tubes behind the crisper, they don’t appear to be frozen.
The problem is, without a model number we’re dead in the water.
