water dispenser not working
Just recently, my water dispenser quit dispensing water. My ice maker is working great!!! What to do??
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn’t come out, the valve is bad. If you don’t hear the valve, the dispenser switch is bad.
If water does come out
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
[quote=woodchuckie;103510]disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn’t come out, the valve is bad. If you don’t hear the valve, the dispenser switch is bad.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.[/quote]
Where is the line to the water dispenser? Is their a diagram of the fridge so I can locate the parts needed to do this? I am fridge-literate!!
