water dispenser not working after filter replacement
I replaced my water filter, and the second or third time I used the water dispenser it made a very loud racket (sort of like a lawnmower) for 20 or so seconds, and then stopped dispensing water. Now when I try and engage the dispenser it will release about a teaspoon of water. If I remove the water filter, it will release about a teaspoon from the filter hookup. I have also tried turning off the power for a few minutes to see if it was something that a reset would fix. My guess is that there was an air bubble, but I can’t figure out why it is permanently broken. There is no water that is leaking anywhere else, even if I try and dispense for a couple minutes.
Any ideas?
Perform the Blue Connector test as described in the attached file to see if the water comes up from the tube. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric PSS26SGRASS Refrigerator | AppliancePartsPros.com
Water is not dispensing.pdf (258.2 KB)
