The water dispenser is broken. The lever was working if I pushed it even farther than previous. Now it does not dispense water at all. The ice dispenser is also problematic. Can I simply purchase the whole assembly and just replace everything? This unit is old so I do not mind replacing the entire assembly.
Hi.
Open the dispenser and check the pins holding the micro switches on the bracket. Most likely they are broken.
The bracket AP6005965
Here are the breakdown diagram and Dispenser front replacement parts for Whirlpool GD25DFXFW01 SIDE BY SIDE REFRIGERATOR | AppliancePartsPros.com
Thank you, Post the results.
Simon.
Thanks. I ordered the part and will reply again and let you know after the install.
Thank you.
Simon.
Praise the Lord! The part worked! Thanks for the diagnosis and the solution!
You are welcome.
Simon.
