Water dispense drips after use
:confused: My water filter was replaced a couple months ago. No problem with water pressure. I have very hard water, the exterior dispensing tube is crusty. I keep a plastic cup under the dispenser. It fills up to about 1" per day, depending upon level of use. Before I spend $ for a repair guy, what parts do I need?
Suggest calling into APPartpros with this one… Typically the solenoid valve will accumulate mineral deposits on the seat that causes the very problem you’re describing with hard water so replacing the valve fixes this.. However, there seems to be valve replacement modifications concerning a ‘Y’ tube so it may be best to call in with your exact model and serial number to assure obtaining the correct parts… cheers kooler
Thanks, I’ll give them a call.
