Thanks for checking those three things! That gives us a much clearer picture of what’s happening with your Whirlpool WRS588FIHZ04.
The fact that the entire display and dispenser light dim when dispensing ice, and the auger motor stops at the same time, is a particularly important clue.
Here’s what your results tell us:
- Water paddle: Dispenses about ½ ounce and stops, but the lights don’t dim.
- Ice paddle: Auger runs briefly, then stops as the display and dispenser light dim.
- Measured Fill: Works normally using the display controls.
Since both paddles have problems, but only the ice dispenser causes the display to dim, I suspect we may have an electrical issue affecting the dispenser circuits.
Here’s what I’d check next.
1. Check the freezer door wiring harness first.
Even though the wiring looks good, a wire can be broken internally or have a poor connection.
Unplug the refrigerator and inspect the harness at the freezer door hinge, especially where the wires bend as the door opens and closes.
If possible, check continuity through the individual wires while gently moving the harness. A reading that jumps between continuity and an open circuit would indicate a damaged wire.
2. Check whether the auger motor is causing the voltage drop.
Since the display dims when the auger operates, the motor or its wiring could be putting excessive load on the electrical circuit.
With the refrigerator unplugged, disconnect the auger motor if it’s safely accessible.
Restore power and briefly press the ice paddle.
- If the display no longer dims: The auger motor or its wiring becomes a strong suspect.
- If the display still dims: The problem is more likely in the dispenser wiring, control circuit, or its power supply.
This test isn’t conclusive by itself, because disconnecting the motor removes its normal electrical load, but it helps narrow the possibilities.
3. Check the control board’s supply voltage.
If you have a multimeter, the next useful test is measuring the dispenser control’s DC supply voltage while pressing the ice paddle.
We want to know whether the voltage remains steady or drops when the display dims.
The correct test points and expected voltage need to be verified from the wiring diagram for this model before probing the board. These are live electrical tests, so only perform them if you’re comfortable working around energized components.
What I’m leaning toward
At this point, I’d prioritize the freezer door harness, auger motor circuit, and dispenser power supply before replacing the main control board.
The fact that Measured Fill works makes a completely failed water valve less likely. And since you’ve already tried another display panel, I wouldn’t replace that again without additional testing.
One more question:
When you press the ice paddle and the entire display dims, does the display immediately return to normal brightness when you release the paddle, or does it stay dim for a few seconds before recovering?
That distinction will help us determine whether we’re seeing a voltage drop under load or a control circuit temporarily shutting down.
