The dishwasher fills up & timer works, element gets hot but lights on panel keep flashing from on to steam and arms are not spraying water?
Hi Julie,
This model number does not come up anywhere because it’s very old. Sounds like the pump gone bad but I can not tell you more specific without proper technical documentation. Also most parts for such old model are no longer available. Probably it’s time for a new one.
Thank You!
The seal leaked and motor went bad. Is there a part available #s62nxfbr-54. Also has a #e22922. The interior is stainless & I would like to fix this one if I can find the part. Thanks!
You have to call the APP customer service (877-477-7278). These part numbers are issued by Waste King and are not available on-line.
