The problem with my washing machine is when I close the lid. The machine fills with water just fine. It just won’t run, unless I slam the lid. Could it be the lid switch? Sometime it doesn’t stay running duriing the cycle.
Replacement parts for MAYTAG A9200 Washer - Top Loading | AppliancePartsPros.com
Here is a manual which should help in replacing it
http://www.servicematters.com/maytag_library/docs/16000131.pdf
Yes could be the switch/switches or the mechanism to close them.
Thank you for the quick reply. I will replace them and see what happens.
