My washing machine completes fill and agitate cycles. However, will not spin. I can not hear the motor at all once the agitate cycle is completed. Recommendations welcome. Thank you
Hello.
The first thing to check in your case would be the lid switch.
To check it remove two screws in the corners of the control panel, lift the top, locate the 3 wire plug going trough the top.
With washer unplugged, install the wire jumper between two outside wires. Turn the washer’s spin.
If it work - replace the lid switch AP5983746
See the attached video for the instructions.
Here are the breakdown diagragms and Replacement parts for Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
