Washing machine won't spin
I have a Whirlpool, model #LSR8244EZ1, top load, Imperial, 8-cycle, 2-speed washer. Was doing laundry and heard a bang when the machine went into the spin cycle. After that couldn’t get the tub to spin. Thank you in advance for your help.
Monty,
Does it agitate and drain?
Would it spin if you will help manually?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSR8244EZ1 | AppliancePartsPros.com
Gene,
Thank you for getting back to me. The machine will agitate and drain, but I can’t get it to spin.
Monty
Monty,
Remove the washer cabinet
[youtube]OlAFQnkapLM&rel=1[/youtube]
and check the motor drive coupling (the instructions are attached).
How to remove the washer cabinet.pdf (43.7 KB)
How to remove the pump.pdf (42.3 KB)
How to replace the motor drive coupling.pdf (39.5 KB)
