Hello, my washing machine will not power on. I checked house electric panel and no curcuites where tripped. I also double checked to make sure the outlet that the washing machine is connected too is working properly and it is. When you tuch the power button no lights at all turn on or even flicker on. The sooner you could get back to me the better! Thank you! Marcello
Without a full model number I can only give you the generic answer which is to replace the control unit.
If that does not fix things, post the results and a full model number and let’s see what else we can figure out.
