My Kenmore washer will go through the wash cycle but will not drain/spin out the water. There is no sound from the motor during this drain cycle. I’ve tried different cycles (i.e. permanent press, ultra clean..) and it does not spin or drain on any cycle. I have not had a problem with this in the past. Do you have any idea what the problem might be? Any help would be appreciated!
Most likely the problem is a bad lid switch. Check if it does click when you close the lid. If it does not, the switch is the culprit.
- The lid switch AP6008880
Hi Gene,
Thanks for the speedy response. I will pick up one today and try to install it by the weekend. Is this a tough task? Wish me luck and thanks again for your help.
By the way, I do not hear a click when the lid is closed.
This job is not too difficult for a DIY person. You have to open the control panel and remove the washer cabinet. Good luck and keep us posted.
I posted almost the same question yesterday and got no response, I am glad you did. I just ordered a new pump and will attempt to replace that. My washer always stops when I open the lid, which is why I am trying the pump first.
Melinda,
Your washer is very different. Your question is answered here: http://forum.appliancepartspros.com/washer-repair/122401-washing-machine-stopped-midcycle.html#post271268
Hi Gene,
This is a beautiful day! I got my washer FIXED this morning. It was the lid switch and my husband and I had it replaced in about 20 minutes. It took a little longer because I cleaned all the residue off the inside and scrubbed down the outside. It looks and runs like NEW! I enjoy a challenge and I’m glad I took the plunge. It saved me over $100. Thank you so much for your help. You are a jewel!!
By the way, I noticed rust on the right side of the tub mount. I’m wondering if it has anything to do with the bleach dispenser being on that side. Can I put anything on the rusty area to prevent further rusting? Have a blessed day.
Regarding the rust - I believe a sandpaper and some paint can help.
I just wanted to thank you for this wonderful information. I have a Kenmore 110.23812100 purchased in 2002. This weekend it stopped working. It would wash but would not drain or spin. I went in panic mode OMG have to buy a new machine…or pay I’m sure around $100.00 for a 20 min repair. After going to the Consumer Report web site to chekout machines I decided to Google “110.23812100 won’t drain or spin”. It found several sites including this forum. I decided to DIY and bought the lid switch. Amazon.com had it for $12.95 + 4.99 Shipping. A lot less than Sears. Worse case if it doesn’t resolve the issue a whopping $17.94…ordered online Monday, delivered by Wednesday. It took me about an hour and a 1/2. I’m sure much longer than an expert…but what they hey (I’m a female and there were no instructions) I was so proud of myself when I plugged the washer back in , turned the knob and heard that wonderful sound of draining and spinning. This forum is wonderful!
I love the internet. I put the question in my browser and this website pops up with the correct answer. I ordered the $10 part on amazon and pulled up a great instructional video on youtube.
$10 and one hour later, this completely inexperienced person, who has never taken apart an appliance, is now doing a load of laundry.
Thanks for the great advise and saving me money! ![]()
Gene,
Thanks so much for the repair instructions for the lid switch. The video was the key. I actually did the repair myself and I’m not a repair type person. The part was not expensive at all and you saved me so much money. I will always check out this forum first when something else needs repair. Thanks again.
tahfrog
You are welcome. I’m glad we were able to help.
Hi Gene,
Thank you for sharing this video! I’m the most mechanically challenged person I know (seriously, I have trouble putting together a simple bookshelf) but with this video I was able to fix my washer all by myself. I’m super proud of myself and am happy to be doing laundry again.
Thanks again! ![]()
Ali
You are welcome Ali. I’m glad it did work for you.
My washer needs the ld switch replaced but my aching is full of wet towels and water. How do I drain the machine to be able to fix it?
What is the complete model number of the washer?
Kenmore model 3356472 Washing Machine
I replaced the Lid Switch and still I have no spinning or draining. What next? Everything else works.
Thanks…Denise
Hi Denise,
Does it agitate?
Does it do anything when it should drain and/or spin?
The model number you posted is incomplete. Verify and repost it please.
