When I put my washing machine on cold/cold, the machine pulls and fills water from the cold side and I felt the hose to make sure it was cold water going in—it is. But whenever I open the washing machine after the load cycle finishes its steaming hot…like burn your face hot and the water and clothes are super hot too. I’m at a loss because the water is cold going in, but then ends up steaming hot!!! Please help!
What is the complete model number of the washer?
Whirlpool
WFW9250WW00
Remove the rear panel. Check the temperature sensor. Check the heater. Check for continuity between each of the heaters terminals and the ground. All instructions are attached. If there is nothing wrong replace the CCU.
The temperature sensor 8181705
The heater assembly 8182666
The CCU W10299981
Here are the breakdown diagrams and Parts for Whirlpool WFW9250WW00 Washer - AppliancePartsPros.com
Duet sport - Removing the rear panel and MCU.pdf (501.7 KB)
Duet sport - Removing the temperature sensor and heater.pdf (401.2 KB)
Duet sport - Testing the temperature sensor and heater.pdf (201.0 KB)
Duet sport - the CCU connectors and removal.pdf (501.0 KB)
