I am having trouble with my whirlpool washer. It won’t start. When it stopped working it made a buzzing sound. I know it’s not the lid switch. So I purchased a new timer from you guys. After installing it, it still makes the same buzzing sound. I have checked the outlet and the breaker. I also visually checked all the connections and wires. It fills with water and then nothing. Just the same buzzing. I have even tried kicking it. Please help. Thank you for this free repair forum. Sincerely, jeffsdad
Refrigerators are not easy to fix when something goes wrong with them. It is highly preferable to ask for the assistance of experts such as Domestic Services who can fix your refrigerator for you in no time. You can call them anytime.
Okay, start by checking the pump for an obstruction, maybe Jeff’s sock is caught in it.
If the pump is okay, check the coupling, maybe it is broken and jammed. Your next choices are the capacitor and the motor, but very unlikely. Also, remember that you can return the timer if you need to.
