Brand:kenmore
Model Number: 110. 16852500
**Main Symptom:**Coupler is good. And clutch seems good. Just received a new clutch from you guys today and it’s in the same shape as the old one . Transmission is leaking oil tho and when I turn the coupler with the belt the long metal shaft will sometimes spin with it and other times not
