loud noise while in spin cycle any suggestions
The likely problem is with the brake assembly. See the Sticky by Richappy at the top of this page for info.
If you replace a part or even buy a whole new unit, after a while you’re going to face the same problem. A new unit may not sound that loud initially, but eventually, it will.
The loud noise from the washing machine will soon or later resume again. You need to look for the permanent solution for this. You can consider shifting your laundry room to another room. But it may not work with everyone. The white noise will somehow travel through the walls and reach your years anyway.
I’ve solved my issue by soundproofing my laundry room. The soundproofing products were much cheaper than buying a new washing machine or even cheaper than replacement parts(which are eventually tend to make noise).
Using anti-vibration pads for your washing machine can stop the noise from leaking into the floor.
This How To SoundProof My Laundry Room guide will surely take you through all cheap and easy ways to quieten your washing machine.
