Washing machine, no hot water
I have an LG washing machine that will not get hot water. I’ve checked the water coming in from the wall to make sure it’s hooked up properly. I have cleaned the screens. I’ve done some other troubleshooting.
Brand:LG
Model Number: WT7200CW
Main Symptom: no hot water
What happens & when: All the time.
If the back panel of the console is removed, the hot water valve can be tested for voltage during a fill cycle. When the washer is set to a hot water wash, the solenoid with an orange wire and a blue wire attached should receive 12 Volts DC. Does voltage reach the valve or does voltage only go through to the solenoid with the yellow and blue wires? If voltage does reach the hot water solenoid and hot water does not come through, the valve assembly would have an issue. AJU75152601 Washer Water Inlet Valve | Genuine Lg OEM In Stock
