Machine first started making load grinding noise while running. Next time it was used it filled up with water went through wash cycle making noise then it stopped. It would not drain. Now all it will do is make very load buzzing noise.
Remove the cabinet. Remove the pump from the motor and see if it’ll work. Possible a foreign object inside the pump.
Post the results.
- Here are the break down diagrams for the Kitchen Aid washer Model KAWS700GQ0
