Asko wash machine model w6021 leaks water from front bottom left corner.. Tub fills with water even when machine off… Stoped only when water supply turned off… Not sure but suspect fill pump???
Any expert help would be much appreciated
Change out your water valves and see if that does not fix both problems. I am not familiar with your brand so I cannot tell you how, but it should be pretty easy to access to valves.
