Washing Machine does not seem to have power
RAS8244LQ1. There seems to be no power going to the washer when I looked at the cycle the cycle just started. I have tried different cycles and that has not helped. Checked the circuit breaker and the outlet and even tried a different outlet and still the washer does not work. There is Standing water in the washer right now. I have removed the clothes from the washer and tried starting again to see if there was an automatic load bearing shutoff but that has not helped.
Your model number does not come up, but try checking the lid switch.
If that is ok, post a good model number and let’s see what else we can come up with.
Found the problem it was an electrical problem and there was no power to the motor. Needless to say it was too much to have repaired so we ended up getting a new one that will last a little bit longer
Sounds like a good decision, good luck with your machine.
