Washing machine control board programming issues
Brand: GE
Model Number: GTW680BSJ6WS
Main Symptom: control board won’t program
What happens & when: lights light up and it goes blank when personality is looked for
You should have received a instruction sheet explaining how to program the new board. Without the programming, it will not work. Did you receive the instruction sheet?
Yes, and that’s where the problem arises. When I plug the machine in, all the led lights blink like it says it will. Then I’m supposed to press start to choose a personality. When I press start, everything goes blank and nothing responds. They sent me another board and the same results.
Have you tried the field service mode ?
I did with the last board and it would never light up to let you know anything. Once you mash start, everything goes blank and won’t come back on. I can put the original board back in and it works. It still jumps between hours and minutes and cycles, but it works. The new ones won’t get past the start button.
In that case, it is either the wrong board and/or the wrong directions. is this the part you ordered and received? WH22X35757 Washer Main User Interface Control Board | Genuine Ge OEM In Stock
Yes. Both the boards sent to me are that number.
Any suggestions for me to try?
Not really, if the part is correct, it comes down to programming.
How am I supposed to program a board that won’t go to the next step?
Did you ever resolve this? Having the same issue as you describe here. Thanks.
I’m having the same exact issue, and am finding this exact scenario described all over different forums and websites. Is there a fix or some updated procedure? The one in the box does not work.
