My machine washes only in the Heavy wash setting. Will not was on Power Wsh, Medium or Light Settings. Timer continues thru these settings and every thing else seems to work OK. Is this a bad timer?
Since it will go through a complete cycle on heavy I would say it is a bad timer. Try replacing it, if you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions.
